IKKO ITX01 Hub USB / HDMI / SD / Jack with DAC
The Ikko ITX01 is a versatile hub, offering a wide range of connectivity to connect many devices. There are three USB-A 3.2 ports, two USB-C 3.2 ports, one of which benefits from the USB-PD 100W fast charging technology, an HDMI 2.0 4K 60Hz output, an SD slot and a Micro SD slot as well as two audio outputs in Jack 3.5mm and Jack 4.4mm formats.
Reference : 16831
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 22-04-2025.
Ikko ITX01
Ikko ITX01 Hub USB / HDMI / SD / Jack
The Ikko ITX01 is a versatile hub, offering a wide range of connectivity to connect many devices. There are three USB-A 3.2 ports, two USB-C 3.2 ports, one of which benefits from the USB-PD 100W fast charging technology, an HDMI 2.0 4K 60Hz output, an SD slot and a Micro SD slot as well as two audio outputs in Jack 3.5mm and Jack 4.4mm formats. The ITX01 also has an audio decoding capacity thanks to its SNC8600 DAC and even offers three operating modes: game, movie or music.
Product typeHub USB / HDMI / SD
Connectivity1x USB-C PD 100W
1x USB-C 3.2 (Data)
1x HDMI 2.0 output (4K 60Hz)
3x USB-A 3.2
1x SD slot
1x Micro SD slot
1x Jack 3.5mm output
1x Jack 4.4mm output
DAC chipSNC 8600
SNR100dB
THD0.01%
Max output level64mW
Supported sampling ratesPCM up to 192kHz
CompatibilityAndroid, iOS, Mac OS, Windows 10 / 11, PS5, Nintendo Switch
ColorGray
Package1x Ikko ITX01
1x Transport bag
Length (m)N/A
ShieldingNC
Section (mm²)N/A
ConnectorUSB-C
ConnectorHDMI
ConnectorMicro SD
ConnectorUSB-A
Conductors material (Cable)N/A
Conductors Plating (Cable)NC
The Ikko ITX01 is a versatile hub, offering a wide range of connectivity to connect many devices. There are three USB-A 3.2 ports, two USB-C 3.2...
