LINDY CROMO LINE Gold Plated Male USB-A / Male USB-B 2.0 Cable 2m
The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a technical reality, to meet a need for fast and reliable transfers.
4.7 / 5
Reference : 13618
10,50 €tax incl.
8,75 € tax excl.
Shipping date: 16-04-2025.
Lindy Cromo Line USB Cable
Lindy Cromo Line Câble USB-A Mâle / USB-B Mâle 2.0 Plaqué Or 2m
Cromo Line USB 2.0 cables have double shielding and tinned copper conductors for fast and loss-free data transmission. The connectors are 24-carat gold plated to ensure high corrosion resistance and durability. Transfer speeds up to 480Mbits/s are supported.
This Lindy Cromo Line cable is 2m long and consists of a USB-A male connector and a USB-B male connector. It will be particularly useful for connecting many HiFi devices with other devices, such as a computer for example.
Product typeUSB Cable
Connectors1x Male USB-A 2.0
1x Male USB-B 2.0
Length2m
Cable conductors materialTinned Copper
Conductors section24AWG / 28AWG
Cable diameter4.6mm
Cable sheath materialPVC
Cable shieldingBraided Copper (Cover : 85%)
Connectors platingGold 1µm
Connectors pins materialCopper alloy
Connectors pins platingGold 3µm
Connectors body materialChromed ABS
Connectors dimensionsUSB-A : Approx. 16 x 35 x 8.3mm
USB-B : Approx. 11.8 x 35 x 10.2mm
ColorsCable : Gray
Connectors : Chrome
Length (m)2.0
ShieldingYes
Section (mm²)0.205
Section (mm²)0.0810
ConnectorUSB-A
ConnectorUSB-B
3 reviews
Câble classique, bon rapport qualité/prix.
Câble classique, le construction à l'air solide.
L'habillage des prises en plastique chromé fait un peu cheap je trouve mais la connectique elle même est de bonne qualité.
Il fait son boulot pour relier mon PC à un reclocker USB.
A ce prix il n'y a rien à dire.
Livraison Audiophonics parfaite, comme toujours.
This review has been posted for LINDY CROMO LINE Gold Plated Male USB-A / Male USB-B 2.0 Cable 2m
Vraiment superbe !
Voici un excellent câble dont la qualité de fabrication est impeccable et dont le prix est absolument imbattable étant donné le haut niveau de finition. Utilisé pour relier un ordinateur à un DAC, la liaison est tout simplement parfaite. Quand on pense que certaines marques célèbres et même encensées par les critiques osent vendre des câbles de ce genre à plus de 10 ou même 100 fois ce prix, imaginez le bénéfice colossal de l’opération… Leur marketing prétend évidemment de meilleur performance audio plus le prix augmente mais en réalité n’importe quel câble suffisamment bien construit suffit pour garantir un signal numérique bit perfect via la liaison USB. Quelques notions en physique et électronique suffisent d’ailleurs pour le vérifier et le démontrer. Quant à dire que les audiophiles sont pris pour des vaches à lait sans cervelle, il n’y a qu’un pas. Bref, vous avez normalement compris, ce câble est tout ce qu’il vous faut et en prime, c’est une affaire à ce tarif !
cheap cable
i buy it for more longer cable, plastic stetic but it works well
The Cromo series is the most powerful USB cables manufactured by Lindy. This one relies on a well thought out design and oriented towards a...
