USB Hub 5 ports with external power supply| Logilink
Connect more electronic devices to your work station without sacrificing space and time reajusting every connection. This USB Hub by Logilink is the perfect tool to charge multiple devices at the same time or to link many data sources to your computer/laptop. Easy to install and convenient for a daily use.
Reference : 12620
16,90 €tax incl.
14,08 € tax excl.
Hub USB 5 Ports Logilink
Hub usb fast charge
Upgrade your workstation and stop wasting time plugging and unplugging again and again your devices to your computer/laptop. This USB Hub can add 5 more USB ports to your primary device, one of which is over-powered to allow a very fast charge of any electronic device.
Unlike most USB hubs, this one has its own power supply, meaning it will keep charging your cellphone even when your computer is unpowered.
This hub allows data trafic between all connected devices and the main source.
Its sleek and elegant design with its tiny size makes the Logilink Usb fast charger very easy to store.
A strong aluminum case ensure a good resistance against scratchs and impacts.
Caracteristics :
  • Case: Aluminum
  • Ports USB : 5  ( 1 allowing super fast charge 2.1 A)
  • Port Micro-USB : 1
  • Power Supply : 5V 2A
  • Dimensions : 97.1 x 34.4 x 68.25 mm
Additionnal items :
  • Power supply
  • Micro-USB Cable
  • User Manual
Length (m)N/A
Section (mm²)N/A
ConnectorUSB-A
Conductors material (Cable)N/A
LOGILINK Hub USB 2.0 5 Ports Fast Charge
Connect more electronic devices to your work station without sacrificing space and time reajusting every connection. This USB Hub by Logilink is...
