Male USB-B to Male Micro USB OTG Cable 15cm
This high-quality OTG USB cable includes OFC copper conductors and gold-plated connectors (USB-B / Micro USB). In addition, being OTG you will be able to use it to connect USB devices to your compatible OTG devices.
4.0 / 5
Reference : 12457
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 16-04-2025.
USB-B to Micro USB Cable
Copper conductor, double shield
Câble USB 15cm
This cable integrates a USB-B connector on one side and a Micro USB connector on the other. Both connectors are Gold Plated to ensure oxidation resistance and therefore greater durability. In addition, its OFC copper conductors ensure excellent signal conductivity and its double shielding reduces potential interference that could degrade the signal. The cable also has an elegant black braided sheath, giving it both flexibility and strength.
In addition, it is an OTG cable, which means that USB devices can be connected to compatible OTG devices, such as a smartphone for example.
OTGYes
Conductor materialOFC Copper
ShieldDouble (foil + braided)
SheathBraided
Length15cm
Connectors platingGold
Length (m)0.1
ShieldingYes
Section (mm²)N/A
ConnectorUSB-B
ConnectorMicro USB
Très bon produit
De beaux composants bien assemblés. Fonctionne parfaitement pour récupérer signal audio numérique sur prise USB d'un smartphone Samsung.
Petit bémol : J'aurais préféré que l'alignement des deux prises soit décalé de 180° mais la rigidité du câble n'autorise aucune torsion de celui-ci.
This review has been posted for Male USB-B to Male Micro USB OTG Cable 15cm
This high-quality OTG USB cable includes OFC copper conductors and gold-plated connectors (USB-B / Micro USB). In addition, being OTG you will be...
