Male USB-B to Male Micro USB OTG Cable 50cm
This high-quality OTG USB cable includes OFC copper conductors and gold-plated connectors (USB-B / Micro USB). In addition, being OTG you will be able to use it to connect USB devices to your compatible OTG devices.
Reference : 12458
17,90 €tax incl.
14,92 € tax excl.
USB-B to Micro USB Cable
Copper conductor, double shield
Câble USB 50cm
This cable integrates a USB-B connector on one side and a Micro USB connector on the other. Both connectors are Gold Plated to ensure oxidation resistance and therefore greater durability. In addition, its OFC copper conductors ensure excellent signal conductivity and its double shielding reduces potential interference that could degrade the signal. The cable also has an elegant black braided sheath, giving it both flexibility and strength.
In addition, it is an OTG cable, which means that USB devices can be connected to compatible OTG devices, such as a smartphone for example.
OTGYes
Conductor materialOFC Copper
ShieldDouble (foil + braided)
SheathBraided
Length50cm
Connectors platingGold
Length (m)0.5
ShieldingYes
Section (mm²)N/A
ConnectorMicro USB
Beter than iFi
I had the iFi 15 cm micro USB OTG with a another quality 50cm to USB-B,
but this cable sounded immediatly more clear and direct, including bass.
This review has been posted for Male USB-B to Male Micro USB OTG Cable 50cm
This high-quality OTG USB cable includes OFC copper conductors and gold-plated connectors (USB-B / Micro USB). In addition, being OTG you will be...
