Lightning to Micro USB OTG USB Cable
The OEOTG from OEAudio is a USB OTG cable of excellent quality, benefiting from a careful design, using components to ensure very good performance.
It integrates insulated OFC copper conductors with a cross section of 0.081mm² (28AWG) for data transmission and a conductor, also made of OFC copper but with a cross section of 0.129mm² (26AWG) for power supply. Each conductor is independently insulated with a PVC sheath. In the center is a 0.4mm diameter OFC copper drain wire. The assembly is shielded with aluminum foil to eliminate interference. A PVC sheath covers the end of this cable. Solderings are made with silver tin to maintain an excellent conductivity.
This cable is fully compliant with USB 2.0 Hi-Speed specifications and therefore has an impedance of 90 Ohm. It also supports a voltage of 5V and a current of 200mA.
This model is equipped on the one hand with a Micro USB connector and on the other hand with a Lightning connector.
Product type | OTG USB Cable |
Connectors | 1x Male Micro USB 1x Male Lightning |
Length | 12cm |
Conductors | OFC Copper |
Conductors section | DATA : 0.081mm² (28AWG) POWER : 0.129mm² (26AWG) |
Shielding | Aluminum foil |
External sheath | PVC |
Impedance | 90Ω |
Voltage / Current | 5V 200mA |
Length (m) | 0.12 |
Shielding | Yes |
Section (mm²) | 0.0810 |
Connector | Lightning |
Connector | Micro USB |
Conductors material (Cable) | Copper |
