OEAUDIO OEOTG Lightning to USB-C OTG Cable 12cm
The OEOTG from OEAudio is a USB OTG cable of excellent quality, benefiting from a careful design, using components to ensure very good performance.
Reference : 14937
32,90 €tax incl.
27,42 € tax excl.
OEAudio OEOTG
OEAudio OEOTG Câble USB OTG Lightning vers USB-C
It integrates insulated OFC copper conductors with a cross section of 0.081mm² (28AWG) for data transmission and a conductor, also made of OFC copper but with a cross section of 0.129mm² (26AWG) for power supply. Each conductor is independently insulated with a PVC sheath. In the center is a 0.4mm diameter OFC copper drain wire. The assembly is shielded with aluminum foil to eliminate interference. A PVC sheath covers the end of this cable. Solderings are made with silver tin to maintain an excellent conductivity.
This cable is fully compliant with USB 2.0 Hi-Speed specifications and therefore has an impedance of 90 Ohm. It also supports a voltage of 5V and a current of 200mA.
This model is equipped on the one hand with a USB-C connector and on the other hand with a Lightning connector.
OEAUDIO OEOTG Câble USB OTG Lightning vers USB-C
Product typeOTG USB Cable
Connectors1x Male USB-C
1x Male Lightning
Length12cm
ConductorsOFC Copper
Conductors sectionDATA : 0.081mm² (28AWG)
POWER : 0.129mm² (26AWG)
ShieldingAluminum foil
External sheathPVC
Impedance90Ω
Voltage / Current5V 200mA
Length (m)
  • 0.12
Shielding
  • Yes
Section (mm²)
  • 0.0810
Connector
  • Lightning
  • USB-C
Conductors material (Cable)
  • Copper
Conductors Plating (Cable)
  • None
Très bon cable
Excellent câble d'une bonne rigidité. Le son est transmis de façon parfaite la prise lightning est bien maintenu sur mon mobile ce qui n'est pas le cas pour tous les câbles. La qualité est là. Le service client que j'ai eu l'occasion de tester (panne informatique de la poste) est compétent et rapide (moins de 8h pour la réponse . Très bonne enseigne, très bon produits je reviendrai. A+++
This review has been posted for OEAUDIO OEOTG Lightning to USB-C OTG Cable 12cm
