PANGEA Premier XL Cable USB-A Male/USB-B Male 2.0 Gold plated Cardas Copper 1m
4.0 / 5
Reference : 11895
139,00 €tax incl.
115,83 € tax excl.
Pangea Audio offers an original and pragmatic vision of its new Pangea Audio Premier XL reference USB cable.
A logical construction of high quality:
The design of the designer Jay Victor for the Pangea Premier XL uses to transport the digital signal and voltage two separate cables. The only point of contact between the two cables is at the USB B connector.
By using two USB ports on his computer, there can be no electrical mains pollution on the digital digital signal DATA USB.
It has 23 precisely wound twisted strands using the best copper on the original Cardas market plus a 6% pure silver plating guaranteeing electrical characteristics over time (oxidation). It also features an insulation of PE foamed polyethylene injected with nitrogen.
pangea USB premier XL
This cable has a quadruple shield screen with braid and aluminum strip inserted in a braided nylon braided sleeve for the mechanical maintenance of the USB cable.
Copper of Cardas origin of high purity:
Copper Cardas Grade One Copper is extracted in Arizona, then shipped to a New England factory where it is extruded slowly in a process of reductionstep annealing to purify and fuse the copper. This method is considered by specialists as offering the most pure copper available on earth.
Thanks to its elegant structure, its physical separation of the digital digital signal and the 5V electrical voltage, the induction and the EMI / RFI pollution are thus lowered, guaranteeing a very low jitter transmitted to the quality USB and DAC interfaces.
Designed with intelligence and quality copper strands (Cardas), the Pangea Premier XL USB delivers a fearsome sound quality on the market.
This cable can be used with our lilinear regulated USB 5V dedicated Audiophonics RASPBERRY PI.
Connection example (sold separately)
Alilinear regulated USB 5V dedicated Audiophonics RASPBERRY PI.
Audiophonics Streamer Raspdigi
pangea USB premier XLpangea USB premier XL
Length (m)1.0
ShieldingYes
Section (mm²)N/A
ConnectorUSB-B
ConnectorUSB-A
Conductors material (Cable)Cardas Copper
Plus efficace qu'il n'y paraît
Pas d'effet "wow", pas la révolution timbrale dans le système, mais un ensemble de qualités fondamentales qu'on oublie un peu au profit du "sensationnel".
En comparaison directe avec mon Wireworld Platinum 7, c'est globalement (un peu) moins ascendant, mais surtout plus plein, plus incarné, avec du poids sur les notes et les transitoires. Les textures dans le bas-médium offrent davantage de matière, sans empâter l'ensemble. Plus différencié aussi, notamment dans l'aigu.
Et au final, toutes ces nuances ont un côté naturel … donc très important ! (PS : prix ultra-raisonnable, bien sûr !)
This review has been posted for PANGEA Premier XL Cable USB-A Male/USB-B Male 2.0 Gold plated Cardas Copper 1m
