PANGEA PREMIER XL MKII Male USB-A to Male USB-B Cable Silver Plated Cardas Copper 0.5m
With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity.
4.0 / 5
Reference : 17021
99,00 €tax incl.
82,50 € tax excl.
Shipping date: 25-04-2025.
Pangea Audio Premier XL MKII Câble USB-A Mâle vers USB-B Mâle Cuivre Cardas Plaqué Argent 0.5m
With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity. The data and power supply cables are completely separate, each with a double shield of aluminum foil and silver-plated copper braid. This special design minimizes the impact of interference on the signal. Each conductor is also insulated with a PE sleeve. The connectors are gold plated to ensure durability.
Product typeUSB Cable
Length0.5m
Connectors1* Male USB-A
1* Male USB-B
Cable diameter2*Ø6.5mm
Conductors materialSilver plated Cardas copper
Conductors sectionData: 0.258mm² (23AWG)
Power supply: 0.653mm² (19AWG)
Conductors insulation sheathPE
ShieldingQuad
Aluminum foil
Silver plated copper braid
Connectors contacts platingGold
Covering sleeveBraided nylon
ColorBlack and silver
Length (m)0.5
ShieldingYes
Section (mm²)0.258
Section (mm²)0.65
ConnectorUSB-A
ConnectorUSB-B
Un réel gain
Comme tous les avis sur les câbles USB, je commence par du scepticisme transformé en conviction.
J'ai changé l'USB fourni avec le DAC iFi Zen One signature pour le connecter à un net-top. L'effet est clairement là, c'est surprenant.
Pour en avoir le coeur net j'ai testé avec un autre câble acheté en boutique hifi pour +/- 50€, idem, gain en précision et détails.
Je ne suis pas certain que cela vaille les 100€ cela dit mais le gain est garantit
This review has been posted for PANGEA PREMIER XL MKII Male USB-A to Male USB-B Cable Silver Plated Cardas Copper 0.5m
With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It...
