PANGEA PREMIER XL MKII Male USB-A to Male USB-B Cable Silver Plated Cardas Copper 1m
With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity.
Reference : 17022
129,00 €tax incl.
107,50 € tax excl.
Shipping date: 25-04-2025.
Pangea Audio Premier XL MKII Câble USB-A Mâle vers USB-B Mâle Cuivre Cardas Plaqué Argent 1m
With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It consists of silver-plated Cardas copper conductors for maximum conductivity. The data and power supply cables are completely separate, each with a double shield of aluminum foil and silver-plated copper braid. This special design minimizes the impact of interference on the signal. Each conductor is also insulated with a PE sleeve. The connectors are gold plated to ensure durability.
Product typeUSB Cable
Length1m
Connectors1* Male USB-A
1* Male USB-B
Cable diameter2*Ø6.5mm
Conductors materialSilver plated Cardas copper
Conductors sectionData: 0.258mm² (23AWG)
Power supply: 0.653mm² (19AWG)
Conductors insulation sheathPE
ShieldingQuad
Aluminum foil
Silver plated copper braid
Connectors contacts platingGold
Covering sleeveBraided nylon
ColorBlack and silver
Length (m)1.0
ShieldingYes
Section (mm²)0.65
Section (mm²)0.258
ConnectorUSB-A
ConnectorUSB-B
L'usb a son meilleur.
ce câble me donne un bon rendu en entée d'DDC singxer su 6 en sortie ver un DAC HOLO AUDIO SPRING 3 , j'utilise un cable PANGEA PREMIER SE MKII Câble HDMI 2.1 en format I2s Tout vient de chez Audiophonics . le rendu sonore est exeptionnel .
This review has been posted for PANGEA PREMIER XL MKII Male USB-A to Male USB-B Cable Silver Plated Cardas Copper 1m
With the Pangea Premier XL MKII, you get a high quality USB-A to USB-B cable, allowing a perfect signal transmission between your devices. It...
