PANGEA Premier SE Cable USB-A Male/USB-B Male 2.0 Gold plated Cardas Copper 0.5m
4.0 / 5
Reference : 11897
39,00 €tax incl.
32,50 € tax excl.
PANGEA PREMIER SE
Pangea Premier SE is an affordable high-end USB audio cable. This version has a male USB-A connector on the one hand and a male USB-B connector on the other.
The processing of its materials and its structure and connectors / design share the technological core of the excellent Prime XL series from the same manufacturer.
An ideal choice to use with a carefuly chosen DAC.
Impeccable design
usb cable audiophile stereo high definition cheap
The DATA line goes through elaborate conductors made from famous Cardas copper Class Level One. A pure silver plating 6% enhance furthermore the material's already-excellent conductivity. This line also benefits from an advanced form of polyethylene insulation.
The supply line is made of tinned copper conductors. An additionnal shield separates the data lines from the power lines.
The whole is then protected by a quad shield with  silver plated copper braid and double aluminum foil.
A sturdy nylon braid sheath ensures the cable remains firmly held together.
Copper original Cardas high purity
Copper Grade One Cardas Copper is mined in Arizona and shipped in a factory in New England where it is slowly extruded to strands in a several steps reduction annealing process  to purify and merge copper just the right way.
This method is considered by specialists as providing the purest copper available. Due to its elegant structure, low inductance and  very low EMI / RFI sensitivity,  it guarantees a very low jitter between your source and a quality DAC.
With its relevant design and quality materials (Cardas), Pangea Premier SE offers formidable sound performance.
TypeUSB cable
StandardUSB 2.0
Length0.5m
DriverData: 23AWG - Cardas Grade 1 Copper - silver plating 6% - PE insulation.
Power: 20AWG tinned copper - PVC insulation
armouringQuad shield
Silver plated copper braid
Double aluminum foil.
SheathBraided nylon sheath
Length (m)0.5
ShieldingYes
Section (mm²)0.518
Section (mm²)0.258
ConnectorUSB-A
ConnectorUSB-B
Conductors material (Cable)Cardas Copper
Câble de qualité
Utilisé pour raccorder un conditionneur USB et un DAC . Très bonne qualité de fabrication apparente. Câble épais et assez rigide, gage de sérieux .Ergonomie des fiches.
L'intérêt d'un tel cordon est toutefois discutable, le rendu sonore étant identique à un câble basique à 2 €.
This review has been posted for PANGEA Premier SE Cable USB-A Male/USB-B Male 2.0 Gold plated Cardas Copper 0.5m
