The Pangea Audio Premier SE USB cable is designed for audiophiles looking for an affordable and powerful USB audio cable. The Pangea Audio Premier SE is thus designed with the same materials and technical mastery as the Premier XL series.
Il will be the ideal companion of any DAC good value for money.
The Pangea Premier SE USB include high-purity conductors using the best copper processing on the market, the famous.
Class Cardas Grade One, plus a veneer pure silver of 6%. It also has a tinned copper conductor, separately shielded as well as an advanced form of polyethylene PE insulation plus a woven braided nylon sheath maintaining mechanical qualities over time.
This cableit has a quadruple shielding with braid and aluminum strip inserted in a braided nylon woven sheath resistant for the mechanical maintenance of the USB cable.
Copper Cardas Grade One Copper is extracted in Arizona and then shipped to a New England plant where it is extruded slowly in a multi-stage annealing process to purify and fuse copper.
This method is considered by the specialists coeven offering the most pure copper available on earth. Due to its elegant structure, low induction and EMI / RFI pollution thus lowered, it guarantees a very low jitter transmitted to the quality USB and DAC interfaces.
Designed with intelligence and quality copper strands (Cardas), the Pangea Premier SE offers a formidable sound quality on the market.
Length (m) | 1.5 |
Shielding | Yes |
Section (mm²) | 0.518 |
Section (mm²) | 0.258 |
Connector | USB-A |
Connector | USB-B |
Conductors material (Cable) | Copper |
Conductors material (Cable) | Cardas Copper |
Conductors Plating (Cable) | Silver |
