USB 3.2 Cable Male USB-C to Male USB-C USB-PD 100W 20Gbps 4K 60Hz 1m
This 1m USB-C cable uses the USB 3.2 standard. This standard is capable of both transferring audio and video data thanks to its high transmission rate and ensuring fast charging of your devices.
Reference : 17993
7,90 €tax incl.
6,58 € tax excl.
USB 3.2 cable
This 1m USB-C cable uses the USB 3.2 standard. This standard is capable of both transferring audio and video data thanks to its high transmission rate and ensuring fast charging of your devices. It supports a bandwidth of 20Gbps, enabling 4K 60Hz video streams to be transmitted, and supports the USB-PD 100W fast charging protocol.
Product typeUSB-C cable
USB versionUSB 3.2
ConnectorsMale USB-C
Length1m
Bandwidth20Gbps
Quick chargeUSB-PD (Power Delivery) 100W
Max. video resolution4K 60Hz
Cable diameterØ5mm
ColorCable: Black
Connectors: Champagne
Length (m)1.0
ShieldingNC
Section (mm²)N/A
ConnectorUSB-C
Conductors material (Cable)N/A
This 1m USB-C cable uses the USB 3.2 standard. This standard is capable of both transferring audio and video data thanks to its high transmission...
