metal connector, enhanced cable, LED indicator and storage panel
This model of USB / micro USB is illustrated by a pleasant design and a large robustness. Its specifications make it an excellent cable for audio use. However, it will also be appreciated by anyone who wants a reliable cable, sturdy, easy to carry and comfortable in daily use.
The shape of the cable is specially designed to avoid friction, tearing, distortion and crushing. The connectors are rigid metal and held by a flexible zinc alloy joint. As for the micro USB plug (the weakest portion), the latter sees its base molded in a rigid plastic block that constitutes an effective protection against impacts and twists.
The micro-USB connector is equipped with a LED the color and state of which indicates the cable activity.
- Blue: Idle (USB-A connected to a power-supplied source/ No activity on Micro-USB).
- Red: Active (Charge or data transfer in progress).
- Off: Inactive (USB-A connected to a non-powered device or no connection).
Furthermore, a chip protection protects equipment (especially batteries) from overloads and overcharge.
Thanks to an efficient conductor, this cable is capable of providing a fast charge. It has indeed a traditional dedicated data line and a line especially designed for charging. As a result, charging another device is 50% faster than it would be with a regular 1A cable.
Conductors are designed from 43 copper strands. These are maintained by a flame retardant PVC jacket
The cable is provided with loop fastener (Velcro type) useful for properly storing the cable and prevents the formation of knots.
This accessory is also very convenient for fixed and semi-permanent installations requiring basic cable management. This attachment system promotes aesthetic instalation and prevents accidents related to wires hanging freely.
Characteristics | |
Type | Cable USB |
Connectors | USB A Female Micro-USB Male |
Materials | Conductor: Copper Connectors: Zinc |
Length | 1.2m |
Activity indicator | LED (2 colors) |
Weight | 30g |
