USB White Flat Cable USB-C Male TO USB-C Male 2.0 10cm
This high-quality male / male C-type cable allows you to connect any tablet or smartphone with a USB type-C or any type of C-type input such as OTG-compatible DACs.
Reference : 12295
10,90 €tax incl.
9,08 € tax excl.
- USB cable type C male to male -
Ideal for connecting your smartphone
This 10cm flat cable will be the most efficient to connect any battery, OTG-compatible DAC and any USB-type C male to male format accessories for Android smartphones or Android tablets with USB-C connection.
câble usb type c
Voltage compatible5V DC 3A
Length10cm
Connector thickness7.5mm
Thickness of flat cable2.4mm
Miscellaneous
Dimensions10 x 13mm
Weight45g
Length (m)0.1
ShieldingYes
ConnectorUSB-C
This high-quality male / male C-type cable allows you to connect any tablet or smartphone with a USB type-C or any type of C-type input such as...
