ATAUDIO Male USB-C Connector Rhodium Plated ALC5686 DAC
This USB-C male connector will allow you to design your own cables or DIY connectors. This one benefits from contacts and solder pads made of rhodium-plated copper alloy, ensuring both a very good conductivity and resistance to oxidation. A carbon fiber ring prevents external interference.
Reference : 17764
14,90 €tax incl.
12,42 € tax excl.
Shipping date: 15-04-2025.
ATAUDIO USB-C Male connector
ATAUDIO Connecteur USB-C Mâle Plaqué Rhodium DAC ALC5686
This connector also integrates a DAC ALC5686 chip with noise reduction filter and low distortion. Are also present in the circuit, an inductor and an independent crystal oscillator.
The connector and cable are held together by injection of hot melt glue, resin, or sealant.
Product typeUSB-C DAC connector
ConnectorUSB-C male
DAC ALC5686
Contacts platingRhodium
Body materialCarbon fiber ring
Max cable diameter<6mm
Mounting typeTo solder
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorUSB-C
This USB-C male connector will allow you to design your own cables or DIY connectors. This one benefits from contacts and solder pads made of...
