Gold Plated Male USB-C 3.1 DIY Connector
This connector to mount will allow you to create your own cables with gold-plated USB-C connectors. This will allow you to take advantage of the reversible format of this connector, which can be plugged in both directions without making mistakes.
3.0 / 5
Reference : 13541
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 24-04-2025.
USB-C Connector
Connecteur USB-C 3.1 Mâle Plaqué Or DIY
This connector to mount will allow you to create your own cables with gold-plated USB-C connectors. This will allow you to take advantage of the reversible format of this connector, which can be plugged in both directions without making mistakes. In addition, USB-C takes advantage of the USB 3.1 standard for higher transfer rates. The connector is delivered with a plastic housing, to be glued.
Product typeMale USB-C Connector
USB Standard3.1
PlatingGold
OTGNo
MountingTo solder (DIY)
Dimensions (without housing)15.8 x 8.3 x 3.5mm
Max cable diameter (mm)N/A
Mounting typeTo weld
ConnecticMale
ConnectorUSB-C
Fragile
Hard to make a study connector. My soldered connection broke at use.
This review has been posted for Gold Plated Male USB-C 3.1 DIY Connector
This connector to mount will allow you to create your own cables with gold-plated USB-C connectors. This will allow you to take advantage of the...
