Male USB-C 3.0 Connector DIY OTG 5Gbps
This USB-C 3.0 male connector will allow you to design high-quality USB cables. The 3.0 standard allows data rates of up to 5Gbps. In addition, the connector is OTG compatible.
Reference : 15421
1,90 €tax incl.
1,58 € tax excl.
Shipping date: 08-04-2025.
USB-C 3.0 Connector
OTG 5Gbps
Connecteur USB-C 3.0 Mâle DIY OTG 5Gbps
Product typeMale USB-C connector
USB version3.0
OTG
Max bandwidth5Gbps
Mounting typeTo solder
Rated voltage/current5V 4A
Max cable diameter (mm)
  • N/A
Mounting type
  • To weld
Connectic
  • Male
Connector
  • USB-C
Contacts Material (Connector)
  • N/A
Contacts Plating (Connector)
  • Gold
This USB-C 3.0 male connector will allow you to design high-quality USB cables. The 3.0 standard allows data rates of up to 5Gbps. In addition, the...
