Parfait pour alimenter un raspi4 proprement avec un câble et une bonne alimentation
Male USB-C 3.0 DIY Connector
This connector to be mounted will allow you to create your own cables with USB-C connectors. This will allow you to take advantage of the reversible format of this connector, which can be plugged in both directions without making mistakes. In addition, USB-C takes advantage of the USB 3.0 standard for higher transfer rates.
Product type | Male USB-C Connector |
USB Standard | 3.0 |
OTG | Yes |
Contacts | x6 |
Mounting | To solder (DY) |
Dimensions | 16.2 x 8.6 x 3.1mm |
Max cable diameter (mm) | N/A |
Mounting type | To weld |
Connectic | Male |
Connector | USB-C |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | Nickel |
Average votes 5.0 / 5 1 reviews | Why write products reviews ? You can share your feelings about products and help other people by sharing your experience |
