OEAUDIO MULTI-PLUG USB-C Connector with CS46L41 DAC
This handy OEAudio USB-C male connector is used with the brand's Multi-Plug adapter, allowing you to enjoy an interchangeable connector. This USB-C model features a Cirrus Logic CS46L41 DAC chip that offers good decoding performance for accurate sound reproduction.
Reference : 15351
32,90 €tax incl.
27,42 € tax excl.
Shipping date: 24-04-2025.
OEAudio Multi-Plug
OEAudio Multi-Plug Connecteur USB-C avec DAC CS46L41
This handy OEAudio USB-C male connector is used with the brand's Multi-Plug adapter, allowing you to enjoy an interchangeable connector. This USB-C model features a Cirrus Logic CS46L41 DAC chip that offers good decoding performance for accurate sound reproduction. It supports PCM audio streams up to 32bit 384kHz and displays an SNR of 121dB for a distortion lower than -98dB. Moreover, the connector contacts are gold plated to ensure good conductivity and resistance to oxidation.
The Multi-Plug adapter is sold separately.
This connector must be used with the OEAudio Multi-Plug adapter sold separately (see accessories).
Product typeUSB-C Connector
ConnectorMale USB-C
DAC ChipCirrus Logic CS46L41
Contacts platingGold
SNR121dB
Distortion< -98dB
Power0.95mV @ 32Ω
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticMale
ConnectorUSB-C
This handy OEAudio USB-C male connector is used with the brand's Multi-Plug adapter, allowing you to enjoy an interchangeable connector. This...
