OCTAVIO ETHERNET Ethernet RJ45 100Mbps Adapter Cable 3m
The Octavio Ethernet is an adapter that provides the Octavio Stream with a 100Mbps RJ45 Ethernet wired network connection, via the USB-C input of the network drive. This input becomes both the power connector of the device, but also its network access.
Reference : 15982
24,90 €tax incl.
20,75 € tax excl.
Octavio Ethernet
Octavio Ethernet Câble adaptateur Ethernet RJ45 100Mbps 3m
The Octavio Ethernet is an adapter that provides the Octavio Stream with a 100Mbps RJ45 Ethernet wired network connection, via the USB-C input of the network drive. This input becomes both the power connector of the device, but also its network access. Thus, this adapter consists of an input USB-A connector for power, then an RJ45 connector, and finally an output USB-C, to be plugged into the Octavio Stream.
Product typeEthernet RJ45 adapter
Input connectors1x Male USB-A
1x Female Ethernet RJ45
Output connector1x Male USB-C
Length3m
ConnecticMale & Female
ConnectorRJ45
ConnectorUSB-A
ConnectorUSB-C
The Octavio Ethernet is an adapter that provides the Octavio Stream with a 100Mbps RJ45 Ethernet wired network connection, via the USB-C input of...
