Spade to Speaker Terminal Banana Adapter 24k Gold Plated (Pair)
These speaker cable adapters transform a 4mm banana plug into a speaker terminal spade. This will enable you to easily adapt your banana cables to the spade connectors used on certain speaker models and Hi-fi equipment. These adapters feature 24k gold plating to ensure maximum protection against oxidation, while maintaining excellent conductivity.
Reference : 19133
5,50 €tax incl.
4,58 € tax excl.
Shipping date: 22-04-2025.
Banana plug to Speaker Terminal's Spade Adapter 24k Gold-Plated : Pair
Product typeBanana plug to spade adapter
Contacts materialCopper
Contacts plating24-carat gold
Banana plug diameter4mm
Spade spacingØ6mm
Ø9mm
PackageSold by pair (1 red ring adapter, 1 black ring adapter)
Max cable diameter (mm)N/A
Mounting typeTo connect
ConnecticMale & Female
ConnectorBanana / Spade
Coup de genie?
Sans doute que oui si ce n'est que les fourchettes sont legerement hors norme.
Juste un poil pas plus mais suffisant pour que ca ne rentre pas sur des borniers de haute precision.
Sinon, ras.
Encore merci a toute l'equipe Audiosonics !
This review has been posted for Spade to Speaker Terminal Banana Adapter 24k Gold Plated (Pair)
These speaker cable adapters transform a 4mm banana plug into a speaker...
