Heatshrink Tubing 2:1 Ø1.5-13mm Blue 10cm (Set x100)
Reference : 8795
3,90 €tax incl.
3,25 € tax excl.
Shipping date: 24-04-2025.
Set of 100 blue heat shrink tubes with 6 different diameters.
A ratio of 2: 1 means that the diameter of the sheath once heated will be divided by 2: for example for a sheath of 6mm, after being heated its diameter will be 3mm.
Specifications:
  • Retractable Ratio: 2: 1
  • Diameters:
    • 1.5 mm (30 pcs.)
    • 2.5 mm (30 pcs)
    • 4.0 mm (20 pcs)
    • 6.0 mm (10pcs)
    • 10 mm (6 pcs)
    • 13 mm (4 pcs.)
  • Length: 10cm
  • Colors Blue
  • Shrink temperature approx. 120 ° C
https://www.audiophonics.fr/images2/8794/8794_gaines_thermo_kit_bleur_1.jpg
ColorBlue
MaterialN/A
Length (m)Sold by length
Max cable diameter (mm)2.5
Max cable diameter (mm)10.0
Max cable diameter (mm)4.0
Max cable diameter (mm)1.5
Max cable diameter (mm)6.0
Max cable diameter (mm)13.0
