ELECAUDIO CH-22G MK2 Power Connector Switzerland SEV 1011 24k Gold Plated Ø17mm
This Elecaudio CH-22G MK2 connector is a Swiss J-type mains connector (SEV1011). It features an insertion ring limiting the cable diameter to Ø17mm, as well as an internal plastic cable clamp. The contacts are plated with 24k gold. The CH-22G MK2 connector is ideal for DIY power wiring projects.
Reference : 18311
19,90 €tax incl.
16,58 € tax excl.
Shipping date: 22-04-2025.
ELECAUDIO CH-22G MK2 Sector Plug Switzerland SEV 1011 24k Gold-Plated Ø17mm
This Elecaudio CH-22G MK2 connector is a Swiss J-type mains connector (SEV1011). It features an insertion ring limiting the cable diameter to Ø17mm, as well as an internal plastic cable clamp. The contacts feature 24k gold plating for optimum resistance to oxidation and corrosion, as well as optimal conductivity. The gold 24k plating gives the connectors a perfectly smooth, uniform coating, totally free from the imperfections inherent in single-layer plating.
The internal terminal blocks are also worth a closer look. Equipped with large fastening screws, and therefore requiring no soldering, they are capable of accommodating very large conductor diameters, up to 12mm² in cross-section, or Ø4mm in diameter.
As the screw is in direct contact with the cable, we recommend the use of copper ferrules to protect against shearing.
These connectors comply with Swiss standards thanks to their double insulation on phase and neutral poles.
Product typeMains connector
Connector typeJ-type Swiss connector (SEV1011)
Voltage250V 10A
Max. cable conductor cross-section12mm²
Max. cable conductor diameterØ4mm
Contact materialCopper-brass alloy
Contact plating24k Gold
Screw materialStainless steel 304 / 24k gold-plated
Body materialCarbon fiber (PC 94 V-0~1 insulation)
Length90mm
DiameterØ38mm
Weight65g
Package1x ELECAUDIO CH-22G MK2 Power plug
Max cable diameter (mm)17.0
Mounting typeTo screw
ConnecticMale
ConnectorType J (SEV 1011)
Rated current (A)10.0
Excellente qualité
Très belle fabrication. En remplacement d'une prise assez basique sur un câble d'alimentation "audiophile" d'une marque anglaise réputée pour branchement d'un ampli à lampe à un autotransformateur. Excellent résultat après blindage du câble en question avec disparition des bruits de basse fréquence.
This review has been posted for ELECAUDIO CH-22G MK2 Power Connector Switzerland SEV 1011 24k Gold Plated Ø17mm
This Elecaudio CH-22G MK2 connector is a Swiss J-type mains connector (SEV1011). It features an insertion ring limiting the cable diameter to...
