By buying this product you get 36 loyalty points
Main Connector UK 250VAC 13A NCF Alpha Treated Rhodium Plated Copper Ø20mm
The Furutech FI-UK NCF (R) is a UK power connector with an excellent design quality. Its contacts are made of Rhodium plated copper, ensuring both excellent conductivity and resistance to oxidation and corrosion. The body of this connector uses the proprietary NCF (Nano Crystal Formula²) damping technology, using a crystalline material with two active properties. First, it generates negative ions to eliminate static charges. Second, it converts thermal energy into far infrared. Furutech combines this material with ceramic nanoparticles and carbon powder for their piezoelectric damping effects.
Each contact also benefits from the brand's α (Alpha) treatment, a cryogenic and demagnetization process to promote stable and optimized transmission.
Product type | UK Main connector |
Contacts material | Copper |
Contacts plating | Rhodium |
Contacts treatment | α (Alpha) |
Body material | Polycarbonate NCF ABS |
Accepted cable diameters | Ø6-20mm |
Max voltage / current | 250VAC 13A |
Mounting type | To solder |
Dimensions | 48 x 50.2 x 55.8mm |
Color | Black |
Max cable diameter (mm) | 20.0 |
Mounting type | N/A |
Connectic | Male |
Connector | Type G (BS 1363 - IS 401) |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Rhodium |
Rated current (A) | 13.0 |
