RAMM AUDIO NEMA-01 Power Connector US Type B 24k 3µ Gold Plated Transparent Ø16mm
Ramm Audio's Nema-01 is a US NEMA 5-15 Type B power connector with a high-quality, transparent nylon body. Aesthetic and solid, this chassis is perfectly suited to the integration of sophisticated, high-end cables. Its proportions make it ideal for large-diameter cables and conductors.
Reference : 17863
34,90 €tax incl.
29,08 € tax excl.
Shipping date: 22-04-2025.
RAMM AUDIO NEMA-01
Power Connector B-Type 24K 3µ Gold Plated Ø16mm Transparent
RAMM AUDIO NEMA-01 Connecteur Secteur US NEMA 5-15 Plaqué Or 24k 3µ Ø16mm Transparent
This connector accepts cable diameters up to Ø16mm. Thanks to a rubber cable clamp, your large cross-section cables will be securely held in place. Contacts are cryogenically treated and plated with 3µ thick 24k gold for maximum conductivity and resistance to oxidation and corrosion.
Lastly, the internal connection terminals feature large screws and a particularly large contact surface. No soldering is required to integrate your cable, and large-diameter conductors are held firmly in place.
Product typeUS Type B NEMA 5-15 power connector
Mounting typeTo screw
Max cable diameterØ16mm
Max conductors section12.5mm² (Ø4mm diameter)
Contacts treatmentCryogenic
Contacts platingGold 24k 3µ
Voltage / Current125V 15A
StandardNEMA 5-15
FormatType B
DimensionsØ38*80mm
Weight60g
ColorTransparent
Max cable diameter (mm)16.0
ConnecticMale
ConnectorType B (NEMA)
ConnectorNEMA 5-15
Rated current (A)15.0
Ramm Audio's Nema-01 is a US NEMA 5-15 Type B power connector with a high-quality, transparent nylon body. Aesthetic and solid, this chassis...
