VIBORG VM04G NEMA 5-15 Mains US Socket
The Viborg VM04G wall receptacle is a US NEMA female mains connector with 99.98% pure copper contacts. This provides a high level of conductivity. In addition, triple OFC copper/silver/gold plating prevents contact corrosion and oxidation, while maintaining high conductivity.
Reference : 20074
35,00 €tax incl.
29,17 € tax excl.
VIBORG VM04G Female NEMA 5-15 Mains US Socket Pure Copper Silver / Gold Plated 125V 15A
Photo of VIBORG VM04G socket
The Viborg VM04G wall receptacle is a US NEMA female mains connector with 99.98% pure copper contacts. This provides a high level of conductivity. In addition, triple OFC copper/silver/gold plating prevents contact corrosion and oxidation, while maintaining high conductivity. The connector body is made of PA66 and fiberglass for strength and durability. The connector accepts cable diameters up to 8mm.
VIBORG VM04G dimensions
Product typeUS NEMA 5-15 wall mains socket
Body materialPA66 and fiberglass
Contacts materialPure copper 99.98% (L+N)
Phosphorous bronze (G)
Contacts platingOFC copper
Silver
Gold
Acceptable cable diametersØ8mm
Rated voltage/current115V 15A
Dimensions37 x 51 x 51mm
Distance for panel assembly38mm
Package1x Viborg VM04G
Max cable diameter (mm)8.0
Mounting typeTo screw
ConnecticFemale
ConnectorNEMA 5-15
Contacts Plating (Connector)Copper
Rated current (A)15.0
The Viborg VM04G wall receptacle is a US NEMA female mains connector with 99.98% pure copper contacts. This provides a high level of conductivity....
