The Viborg VM04R wall receptacle is a US NEMA 5-15 female mains connector with 99.98% pure copper contacts. This provides a high level of conductivity. In addition, triple OFC copper/silver/rhodium plating prevents contact corrosion and oxidation, while maintaining excellent conductivity. The connector body is made of PA66 and fiberglass for strength and durability. It accepts cable diameters up to 8mm.
Product type | US NEMA 5-15 wall mains socket |
Body material | PA66 and fiberglass |
Contacts material | Pure copper 99.98% (L+N) Phosphorous bronze (G) |
Contacts plating | OFC copper Silver Rhodium |
Acceptable cable diameters | Ø8mm |
Rated voltage/current | 115V 15A |
Dimensions | 37 x 51 x 51mm |
Distance for panel assembly | 38mm |
Package | 1x Viborg VM04R |
Max cable diameter (mm) | 8.0 |
Mounting type | To screw |
Connectic | Female |
Connector | NEMA 5-15 |
Contacts Material (Connector) | Copper |
Contacts Plating (Connector) | Copper |
Contacts Plating (Connector) | Rhodium |
Contacts Plating (Connector) | Silver |
Rated current (A) | 15.0 |
