6 Poles 6.2mm 2 Rows Straight 20A
This JST VL socket allows easy PCB mounting and is ideal for high voltage and high current applications. Featuring 6 poles and a 6.2mm pitch, this model has a PA 66 UL94V-0 housing. Each slot has an integrated locking system to prevent accidental disconnection.
Product type | JST VL Connector |
Number of contacts | 6 |
Number of rows | 2 |
Pitch | 6.2mm |
Nominal voltage | 600V AC/DC |
Nominal current | 20A |
Initial contact resistance | 7mΩ max. |
Standards and certifications | UL E60389 CSA LR20812 TUV R9351103 |
Max cable diameter (mm) | N/A |
Mounting type | To connect |
Mounting type | To weld |
Connectic | Male & Female |
Contacts number | 6 |
Connector | VL |
Contacts Material (Connector) | Copper Alloy |
Contacts Plating (Connector) | None |
