EVA Gasket Double Sided Adhesive 25x1mm 5m Black
This EVA (Ethylene-Vinyl Acetate) gasket will notably allow you to ensure the watertightness of your speakers' body, in order to obtain a perfect acoustic insulation. In addition, this material is highly resistant and helps absorb vibrations.
Reference : 17743
4,90 €tax incl.
4,08 € tax excl.
Shipping date: 29-04-2025.
Gasket
Joint d'étanchéité EVA Adhésif Double Face 25x1mm 5m Noir
This EVA (Ethylene-Vinyl Acetate) gasket will notably allow you to ensure the watertightness of your speakers' body, in order to obtain a perfect acoustic insulation. In addition, this material is highly resistant and helps absorb vibrations. Very easy to use, the seal has a double-sided adhesive. The gasket is 25mm wide and 1mm thick and is delivered in a 5m roll.
Product typeGasket
MaterialEVA
Width25mm
Thickness1mm
Length5m
FixationDouble-sided adhesive
This EVA (Ethylene-Vinyl Acetate) gasket will notably allow you to ensure the watertightness of your speakers' body, in order to obtain a...
