JANTZEN AUDIO Bass Feflex Speaker Vent L 120mm Ø35mm
4.0 / 5
Reference : 11441
1,70 €tax incl.
1,42 € tax excl.
Shipping date: 25-04-2025.
This Jantzen Audio speaker for Bass-Reflex speaker Ø 35 mm will be perfect for any speaker of small diameter from 10 to 15cm.
It will be particularly recommended for loudspeakers of a diameter below 15 cm by a flared headlamp in the form of a horn avoiding the sound of resonances and harmful flows.
De the more the striated forms behind the fattening will facilitate the installation in the pre-cut in touch of facade for a visual result neat.
hecan easily be cut with a simple saw at the right length for an optimum tuning frequency.
Features:/ Strong>
  • Event Bass Reflex, Helmhotz resonator with optimized airflow
  • Anti-resonant PVC material easy to cut
  • Internal diameter: Ø 35 mm
Bon rapport qualité prix
Montés sur des enceintes en MDF plaqué. Nécessite une ouverture aux dimensions exactes. J'ai réalisé un trou de diamètre légèrement inférieur, que j'ai agrandi progressivement à la râpe jusqu'à ce que l'évent puisse entrer. Une fois en place il ne bouge plus et l'étanchéité semble correcte.
This review has been posted for JANTZEN AUDIO Bass Feflex Speaker Vent L 120mm Ø35mm
