MM Phono Preamplifier
The VP1 from Dayton Audio is a small phono preamplifier, compatible with MM (Moving Magnet) turntables. It performs an efficient preamplification of the signal sent by your turntable and ensures a musical and clean sound reproduction. It also includes an RIAA equalization system to obtain a balanced sound reproduction.
Product type | Phono preamplifier |
Type of compatible turntables | MM (Moving Magnet) |
Input | 1x Stereo RCA |
Outputs | 1x Steroe RCA 1x Jack 6.35mm headphone output |
Ground terminal block | |
Input signal | 5mV @ 1kHz (max. -23.5dBV @ 1kHz) |
Output signal | Max. +11dBV @ 1kHz |
SNR | 70dBu |
Input impedance | 47kΩ |
Output impedance | 50Ω |
THD | < 0.05% |
Frequency response | 18Hz - 20kHz |
Supply voltage | 12VDC 500mA |
Dimensions | 104 x 61 x 33mm |
Color | Black |
