FX-AUDIO TUBE-P1 Valves Amplifier with Phono MM Input 6J1 + 6P1 Stereo Silver
The FX-Audio Tube-P1 is a tube amplifier with phono preamplifier input, based on 2 tubes 6J1 and two tubes 6P1. It is therefore ideal for those who want both a tube amplifier and a vinyl turntable.
Reference : 14839
109,00 €tax incl.
90,83 € tax excl.
FX-Audio Tube-P1
Valves amplifier with Phono MM Input 6J1 + 6P1 Stereo
FX-Audio Tube-P1 amplificateur à tubes et Préamplificateur Phono
A valves amplifier with phono input combo
FX-Audio proposes with its Tube-P1 a simple but versatile device having the particularity to be a tube amplifier allowing to deliver 2 x 2.5W but also having a phono input. It will therefore be particularly suitable for anyone who wishes to have a tube amplifier while taking advantage of its vinyl turntable.
Thus, Tube-P1 offers on the one hand a stereo RCA input that will allow you to connect most of your audio sources (CD player, tuner, network player...) and on the other hand a phono RCA input, the latter only accepting MM cell boards. Of course, we notice the presence of a connector to connect the ground of your turntable.
On the output side, there is a front headphone output in 6.35mm Jack format and at the rear an output on speaker terminals, accepting banana plugs. Small particularity, the Tube-P1 proposes a double terminal block in 4Ω and 8Ω, according to your speakers.
Recommended heating time: 20 seconds
Caution: The tubes rise to a high temperature. Do not touch the tubes when in operation and keep out of reach of children. Danger of burns.
Power2.5W + 2.5W
Valves2x 6J1 (Inclued)
2x 6P1 (Inclued)
InputsRCA
Phono (MM)
OutputsSpeakers terminals (4Ω / 8Ω)
Headphone output Jack 6.35mm (16-300Ω)
Power supply12V 4A on Jack DC 5.5/2.1mm (included)
ColorSilver
InputPhono
OutputJack 6.35mm
OutputSpeaker terminal
ColorSilver
ClassTube amp
2 reviews
Fx audio
Surprising:
-price = final sound = great!
Construction:
- solid metal and decently heavy for its dimensions. The connector from the power supply could have been solved better - it moves after insertion. The backlight of the electronics could have been omitted by the manufacturer. In the forums, they criticized the volume control, that it clicks and the like, nothing like that happens. The volume is controlled smoothly and goes smoothly into performance.
Connected options:
-Rca and Phono, solid speaker terminals
Sound:
-tried and listened to for several tens of hours until the electrons burn out (100h). I replaced the original supplied tubes with Russian 6P1P (6П1П) = 6P1 (China)
and 6Ž1P-EV (6Ж1П-EB) VOSKHOD = 6j1 (China). The result? I definitely recommend! Why? The sound device shows the purity, space, depth of the music scene (tested on Tannoy M2, Triangel BR2 .. + device Marantz Se63, Yamaha dvd796, Akai gx32, Tesla NC470, Dynavox RCA + Repro cabling (I recommend both from Audiophonics)). It's surprising to listen to a device that doesn't get tired even after a few hours. You're just devouring music of various genres, whether it's Soul, Jazz, Rock, Classic, Pop .. the device can handle and offers what is expected of an electronic device - the warmth of serving in the form of music.
You can say okay, but what about the power 2x2.5W? I also thought it would be such a "weaker coffee". The space of 30-50 m2 will completely cover with music.
This review has been posted for FX-AUDIO TUBE-P1 Valves Amplifier with Phono MM Input 6J1 + 6P1 Stereo Silver
UK
Surprising:
Construction:
Connected options:
Sound:
The FX-Audio Tube-P1 is a tube amplifier with phono preamplifier input, based on 2 tubes 6J1 and two tubes 6P1. It is therefore ideal for those who...
