IFI AUDIO ZEN AIR PHONO MM/MC Phono Preamplifier
With the Zen Air Phono, iFi Audio offers an affordable yet powerful phono preamplifier. It will allow you to connect your turntable at the input and your amplifier at the output to enjoy your favorite records in high quality. A good phono preamplifier is a must for any vinyl lover and the Zen Air Phono is an ideal solution for those who want to enjoy quality sound reproduction at a low price.
4.5 / 5
Reference : 16627
99,00 €tax incl.
82,50 € tax excl.
iFi Audio Zen Air Phono
iFi Audio Zen Air Phono Préamplificateur Phono MM/MC
MM & MC
The Zen Air Phono fits all vinyl turntables, being compatible with both MM (Moving Magnet) and MC (Moving Coil) cells. A switch on the back of the device allows you to select the type of cell your turntable is equipped with. Moreover, the preamplifier has an RIAA equalization to satisfy the most demanding vinyl lovers.
Subsonic filter
The subsonic filter built into the iFi Audio Zen Air Phono eliminates vibration noise that may be related to the condition of the record.
iFi Audio Zen Air Phono review by Audio Science Review (Amir)
I like the packaging of this ifi phono stage. Distortion and noise is OK... RIAA Equalization though is implemented perfectly and for that, the ifi zen air phono joins my recommended list "
Test du iFi Audio Zen Air Phono par Audio Science Review (Amir)
Product typePhono preamplifier
Input1x Stereo RCA
Output1x Stereo RCA
Compatible cartridge typeMM
MC
Frequency response20Hz-20kHz (±0.15dB)
Channel separation> 75dB (1kHz, all modes)
Max output voltage6.5V RMS 600Ω (< 1% THD+N)
GainMM : 40dB
MC : 64dB
Input impedanceMM : 47kΩ
MC : 1kΩ
Output impedance100Ω
SNRMM (40dN ±1dB) : 86dB (A-Weighted) re 1V
MC (64dB ±1dB) : 82dB (A-Weighted) re 1V
Equivalent input noiseMM : -130dBV (A-Weighted)
MC : -151dBV (A-Weighted)
THDMM : < -90dB / 0.005% re 1V
MC : < -80dB / 0.01% re 1V
Supply voltage5VDC 1A (USB-A to DC jack cable included, AC adapter sold separately)
Consumption< 1.8W
Dimensions158 x 117 x 35mm
Weight320g
ClassN/A
2 reviews
petit preamp phono
excellent petit préampli phono, testé sur son entrée MM
son détaillé et clair ; grand silence sur les blancs grâce probablement à la batterie intégrée et à loa fabrication soignée
This review has been posted for IFI AUDIO ZEN AIR PHONO MM/MC Phono Preamplifier
Pour celui qui ne veut pas de prise de tête pour choisir un prérempli phono, celui-ci est parfait pour un système plus que correct.
Merci à Audiophonics pour l'envoi hyper rapide comme d'habitude.
With the Zen Air Phono, iFi Audio offers an affordable yet powerful phono preamplifier. It will allow you to connect your turntable at the input...
