DAYTON AUDIO VP1 MM Phono Preamplifier
The VP1 from Dayton Audio is a small phono preamplifier, compatible with MM (Moving Magnet) turntables. It performs an efficient preamplification of the signal sent by your turntable and ensures a musical and clean sound reproduction. It also includes an RIAA equalization system to obtain a balanced sound reproduction.
Reference : 15841
32,90 €tax incl.
27,42 € tax excl.
Dayton Audio VP1
Dayton Audio VP1 Préamplificateur Phono MM
Product typePhono preamplifier
Type of compatible turntablesMM (Moving Magnet)
Input1x Stereo RCA
Outputs1x Steroe RCA
1x Jack 6.35mm headphone output
Ground terminal block
Input signal5mV @ 1kHz (max. -23.5dBV @ 1kHz)
Output signalMax. +11dBV @ 1kHz
SNR70dBu
Input impedance47kΩ
Output impedance50Ω
THD< 0.05%
Frequency response18Hz - 20kHz
Supply voltage12VDC 500mA
Dimensions104 x 61 x 33mm
OutputJack 6.35mm
ClassN/A
The VP1 from Dayton Audio is a small phono preamplifier, compatible with MM (Moving Magnet) turntables. It performs an efficient preamplification...
