FOSI AUDIO BOX X2 Phono MM Preamplifier with Tubes 2x6A2 Stereo Black
With its BOX X2 tube preamplifier, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the warm, coated sound of tube amplification. The FOSI Audio BOX X2 is the ideal companion for a power amplifier or a pair of active speakers.
Reference : 18080
59,90 €tax incl.
49,92 € tax excl.
Shipping date: 16-04-2025.
FOSI AUDIO BOX X2
FOSI AUDIO BOX X2 Préamplificateur Phono MM à Tubes 6A2 Stéréo Noir
The BOX X2 features a 4-level gain control (OFF/39/42/45 dB) on the front panel, as well as a 3.5mm jack auxiliary input for connecting various audio sources such as a telephone, DAC, or others. The rear panel features a stereo RCA input and output with a ground terminal for phono coupling with a turntable (MM).
The FOSI Audio BOX X2 is the ideal companion for a power amplifier or a pair of active speakers. It will boost the sound quality of your hi-fi system. Supplied with a pair of 6A2 (7-pin) tubes, these are easily replaceable by JAN 5654W / 6K4 / 6J1 / 6J4 / GE5654 / 6AK5 / 66*In tubes, if you want a different sound. Overall, the BOX X2 is an excellent entry-level preamplifier.
Product typeMM phono preamplifier with tubes
Tubes2x 6A2
Inputs1x Stereo RCA input (with GND terminal)
1x Auxiliary input 3.5mm jack
Outputs1x RCA stereo
Output voltage level 600Mv @3mV 1kHz
SNR≥ 98dB
THD≤ 0.1%
Frequency responseRIAA standard
Gain adjustmentOff
39dB
42dB
45dB
Compatible cell typeMM
GND terminal
Power supplyDC 12V 1.5A
Dimensions118.5 x 98 x 33mm
Weight315g
Package1x MM tube phono preamplifier Fosi Audio BOX X2
2x 7-pin 6A2 tubes
1x Power supply adapter
1x Stereo RCA to 3.5mm jack cable
InputJack 3.5mm
ClassTube amp
2 reviews
Bon préamplificateur phono
C'est par curiosité que j'ai essayé ce petit préamplificateur .
Le résultat est vraiment étonnant compte tenu se son tarif plus que raisonnable.
Sans le modifier pour le moment, le son est déjà excellent, je le teste avec une Thorens TD 125 MK2 équipée d'une cellule Stanton 681 EEE avec un diamant Jico et la comparaison avec des préamplificateur 10 à 15 fois plus cher est étonnante : pas de souffle, une correction riaa stable et une dynamique superbe.
Cerise sur le gâteau il m'a été fourni avec des tubes Ge 5654w de très bonne qualité.
Je recommande fortement ce produit d'un rapport qualité prix imbattable (réservé bien sur aux cellules MM, on ne peut pas tout avoir).
Jacques
This review has been posted for FOSI AUDIO BOX X2 Phono MM Preamplifier with Tubes 2x6A2 Stereo Black
c'est le 2éme avis demandé à Audiophonics : David Aubert
de nouveau très satisfait : écoute vivante sur tout le spectre
bien plus agréable (subjectif ..?) qu'un modèle à transistor plus couteux (!)
par contre un fort sifflement (enceintes haut rendement en multiamplication) facilement controlé en utilisant une autre alimentation basique (fx audio tube 03 pré ampli, même farbicant ?)
With its BOX X2 tube preamplifier, Fosi Audio unveils an affordable, high-quality Hifi device for those wishing to enjoy the...
