FX-AUDIO BOX02 Phono MM/MC Preamplifier NJM2068 TL071
The FX-Audio BOX02 is a low-cost phono preamplifier, offering a very high quality design. It supports the board with MM and MC cells, a switch under the device to select one of the two technologies. The preamplification stage is based on low noise AOPs NJM2068 and JFET TL071C.
Reference : 13463
64,90 €tax incl.
54,08 € tax excl.
FX-Audio BOX02
FX-Audio BOX02 Préamplificateur Phono MM/MC NJM2068 TL071
The FX-Audio BOX02 is a low price phono preamplifier, offering a very high quality internal design. It supports the board with MM and MC cells, a switch under the device to select one of the two technologies. The preamplification stage is based on low noise OPA NJM2068 and JFET TL071C. These offer excellent audio performance in terms of noise and distortion. On the connector side, there is a stereo RCA input for MM or MC turntables and a stereo RCA output to connect the unit to your amplifier. A screw terminal block allows you to add the ground of your board.
The device also offers several settings via 3 DIP switches positioned underneath the device. The first DIP switch allows you to choose between MM and MC cells but also to select a gain level at 0dB or 6dB. The other two DIP switches, each corresponding to a channel (L/R), allow you to select a capacitance and an impedance in accordance with your phono cell. A setting that is usually found mainly on high-end phono preamplifiers.
Product typePhono MM/MC Preamplifier
ComponentsAOP NJM2068
AOP TL071
Output level310mVrms
Input1x RCA phono MM/MC
Output1x Stereo RCA
THD0.8%
SNR-76dB
Geneéral
Power supply12V 1A via Jack 5.5/2.1mm (power adapter included)
Dimensions98 x 130 x 33mm
Weight310g
ColorSilver
Package1x FX-Audio BOX02
1x Power supply
InputPhono
ColorSilver
ClassN/A
4 reviews
Rapport qualité prix imbattable
Tout est dans le titre. Qualité de fabrication , qualité sonore, silencieux même avec sa petite alimentation externe.
Possible qu'il gagnerait avec une alimentation de qualité, à voir...
This review has been posted for FX-AUDIO BOX02 Phono MM/MC Preamplifier NJM2068 TL071
Magnifique
Ma platine vynile avait un préampli intégré qui donnait un résultat plutôt moyen sur un ampli, plutôt moyen également j'avoue... Néanmoins le préampli intégré dans la platine étant "désactivable", je me suis dit que j'allais rechercher un préampli ad hoc. Et bien je ne regrette pas une seule seconde d'avoir fait cet achat. Le résultat est tout simplement un énorme plaisir à réécouter mes vinyles, que je connais par coeur, mais que je redécouvre totalement... c'est génial. Je dirais que le son a gagné en clarté, en précision, en spatialité, en profondeur, en chaleur.... l'effet "melasse" et "distordu" qui commençait à m'agacer sérieusement a totalement disparu. La finition du produit me semble d'excellente facture. Livré très rapidement par audiophonics. Pour moi c'est un 5/5 sans hésiter. Merci !
renaissance de mes vinyles
après avoir beaucoup hésité et des conseils précieux d'AUDIOPHONICS je me suis lancé sur ce préamplificateur phono et je peux confirmer que ça a transformé mon installation .
Ayant une platine technics , ampli vintage sony et enceintes jmalb ,
le BX02 a ravivé tout l'ensemble , les voix sont beaucoup plus claires un gain et un son plus péchu . le boitier est tout en aluminium très qualitatif et solide .les réglages aussi sur le type de cellule la captance et la charge sont très interessante pour affiner .
le Tout à livré très rapidement à un prix imbattable .
merci à toute l'équipe audiophonics .
Bonne pioche !
Après plusieurs heures d'écoute, ce préampli me donne toute satisfaction avec une cellule Audiotecnica et un ampli Alientek D8.
Sa fabrication et son prix sont sans concurrence !
The FX-Audio BOX02 is a low-cost phono preamplifier, offering a very high quality design. It supports the board with MM and MC cells, a switch...
