By buying this product you get 42 loyalty points
Phono Preamplifier MM/MC RIAA Non-Feedback ADC CS8604 24bit 96kHz
Original Audio proposes with the OPA-Q1.1 an RIAA phono preamplifier with an original design, displaying a surprising cylindrical format, carved from a massive aluminum block. Its performances are not however in retreat, this one offering a beautiful musicality. Its circuits use a double field effect tube as well as an AOP for the MM/MC amplification section and its RIAA curve is of Non-Feedback type.
The amplification stage of the OPA-Q1.1 is also neat, with the use of a Z11 Iron Core transformer specially designed for this model.
For its connectivity, the OPA-Q1.1 provides both a classic connectivity of course, with an input and an output in stereo RCA format. However, it also offers a Toslink optical digital output, associated with a CS8604 ADC (analog to digital converter) supporting sampling rates up to PCM 24bit 96kHz.
Product type | MM/MC Phono preamplifier |
Input | 1x Stereo RCA |
Outputs | 1x Stereo RCA 1x Optical Toslink |
ADC Chip | CS8604 |
Input impedance | MM : 51kΩ MC : 100Ω |
Voltage gain (1kHz) | MM : 40dB MC : 60dB |
SNR | MM : 85dB MC : 78dB |
RIAA Bandwidth | 20Hz-20kHz, 0.25dB |
THD | 0.008% (1kHz) |
Output sampling rates (Optical) | PCM up to 24bit 96kHz |
Power supply | 220V 50Hz |
Dimensions | 120 x 995 x 315mm |
Weight | 2kg |
Color | Silver and black |
Body | Aluminium / Plastic |
Operating temperature | 0°C / +40°C |
