By buying this product you get 39 loyalty points
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
The Lunar 1 features a base made of high-density fiberboard (25kg/m3) and an ABS polymer top. These materials absorb vibrations and prevent unwanted resonance, guaranteeing pure sound.
A switch on the side of the turntable makes it quick and easy to select the rotation speed between 33 and 45 rpm.
At the end of the aluminum arm of the Triangle Lunar 1 turntable is an Ortofon OM-5E cell with an elliptical diamond profile. The elliptical diamond profile generally allows for a greater level of detail and a better reading of high frequencies.
The phono cable supplied features HP-OFC copper conductors and gold-plated RCA plugs for enhanced conductivity and resistance to corrosion and oxidation.
Product type | Vinyl turntable |
Turntable type | Manual |
Drive system | By belt |
Playback speeds | 33 and 45 RPM |
Cartridge | Ortofon OM-5E |
Diamond type | Elliptical |
Tone arm type | Straight |
Tone arm material | Aluminum |
Tone arm length | 21.5cm |
Cartridge output voltage | 4mV |
Fréquency response | 20hZ-20kHz |
Output | 1x Stereo phono RCA (with ground terminal) |
Cable | RCA phono interconnect cable (HP-OCC and gold-plated connectors) |
RCA cable length | 1.2m |
Power supply | 5V DC |
Dimensions | 420 x 330 x 112mm |
Weight | 3.5kg |
Color | Cream |
Package | 1x Triangle Lunar 1 turntable 1x Flat belt 1x Dust cover 1x RCA Phono interconnect cable |
