TRIANGLE LUNAR 1 Vinyl Turntable Green
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio.
By buying this product you get 39 loyalty points
Reference : 19611
399,00 €tax incl.
332,50 € tax excl.
TRIANGLE LUNAR 1 Vinyl Turntable 33/45 RPM Ortofon OM-5E  Green
TRIANGLE LUNAR 1 vinyl turntable picture
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is assembled in Europe in partnership with Pro-ject Audio. Drive is via a flat belt, and playback is via a lightweight, low-friction aluminum tone arm specially optimized for the Ortofon OM-5E cartridge. With its distinctive Triangle aesthetic, the turntable matches perfectly with the brand's various speaker ranges. An RCA phono interconnect cable with HP-OFC copper conductors and gold-plated connectors is supplied with the Lunar 1 turntable.
TRIANGLE LUNAR 1 turntable highlights
TRIANGLE LUNAR 1: high-density wood base
The Lunar 1 features a base made of high-density fiberboard (25kg/m3) and an ABS polymer top. These materials absorb vibrations and prevent unwanted resonance, guaranteeing pure sound.
The TRIANGLE LUNAR 1 turntable base
TRIANGLE LUNAR 1 turntable switch
TRIANGLE LUNAR 1: an easy-to-use turntable
A switch on the side of the turntable makes it quick and easy to select the rotation speed between 33 and 45 rpm.
TRIANGLE LUNAR 1: Ortofon OM-5E cartridge
At the end of the aluminum arm of the Triangle Lunar 1 turntable is an Ortofon OM-5E cell with an elliptical diamond profile. The elliptical diamond profile generally allows for a greater level of detail and a better reading of high frequencies.
Photo of the Ortofon OM-5E cell on the TRIANGLE LUNAR 1 turntable
Photo of the phono output of the TRIANGLE LUNAR 1 turntable
TRIANGLE LUNAR 1: HP-OFC copper phono interconnect cable
The phono cable supplied features HP-OFC copper conductors and gold-plated RCA plugs for enhanced conductivity and resistance to corrosion and oxidation.
Product typeVinyl turntable
Turntable typeManual
Drive systemBy belt
Playback speeds33 and 45 RPM
CartridgeOrtofon OM-5E
Diamond typeElliptical
Tone arm typeStraight
Tone arm materialAluminum
Tone arm length21.5cm
Cartridge output voltage4mV
Fréquency response20hZ-20kHz
Output1x Stereo phono RCA (with ground terminal)
CableRCA phono interconnect cable (HP-OCC and gold-plated connectors)
RCA cable length1.2m
Power supply5V DC
Dimensions420 x 330 x 112mm
Weight3.5kg
ColorGreen
Package1x Triangle Lunar 1 turntable
1x Flat belt
1x Dust cover
1x RCA Phono interconnect cable
ColorGreen
Cartridge typeMM (Moving Magnet)
Rotation speed33 RPM
Rotation speed45 RPM
The Lunar 1 turntable from Triangle is a manual turntable designed to play 33 and 45 rpm vinyl records. It features excellent build quality and is...
