Vishay Dale CMF55 are a serie of very high quality resistors. These components benefit from a virtually null inductance and excellent electronic / thermal stability.
These resistors are indeed well known for varying very little with temperature fluctuations. It allows an audio system to run with ideal electronic conditions. This directly reduces overall noise in any electronic circuit, while establishing great operating conditions for other critical components.
The Vishay Dale CMF55 undergo strict quality control to achieve a measurement accuracy of 0.1 to 0.5% with a stability of 50 ppm/°C.
Designed with the highest level of electronic safety standards, these resistors have a flame retardant epoxy coating and excellent overall resistance to thermal stresses.
Type | Resistance |
Value | 11KΩ |
Precision | 1% |
Stability | 50ppm / ° C |
maximum voltage | 250V |
Maximum power | 1/2W |
Insulation | ≥10^11Ω |
Operating temperature | -55 / + 175 ° C |
Noise | 0.10 microvolts / Volt freq / 10yrs |
Weight (max) | 0.20g |
Materials | Nickel-chromium alloy vacuum deposited High purity ceramic Flame retardant epoxy |
Dimensions | ø2.3 x 7mm |
