Insulation Spacer Transistor Components TO-220 / TOP-3 (Unit)
This isolation spacer has dimensions that allow it to be adapted to certain electronic components, in particular transistors in TO-220 or TOP-3 packages. It will allow you to isolate the fixing screw of these components from the heatsink on which they are fixed.
Reference : 14699
0,15 €tax incl.
0,13 € tax excl.
Shipping date: 05-02-2025.
Insulation Spacer
For transistor components TO-220 / TOP-3 (Unit)
Entretoise d'isolation composants transistor TO-220 / TOP-3 (Unité)
Product typeInsulation spacer
Components compatibilityBoîtiers TO-220 / TOP-3
MaterialPolyamide 4.6
GF reinforced
Min/Max temperature-40°C / +250°C
StandardUL 94 V-0
External diameterØ6mm
Outer diameter of central studØ3.5mm
Inner diameter of central studØ3.1mm
Height2.2mm
ColorGray
MaterialPolymere
Screw threadN/A
Screw thread length (mm)N/A
Screw head shapeNone
Screw drive type (socket)None
Conforme
Permet de fixer des TDA7294 sur un dissipateur.
This review has been posted for Insulation Spacer Transistor Components TO-220 / TOP-3 (Unit)
This isolation spacer has dimensions that allow it to be adapted to certain electronic components, in particular transistors in TO-220 or TOP-3...
