Adjustable Discrete Voltage Regulator LM7805 +5V / +12V
This discrete voltage regulator has been designed to replace an LM7805 IC model (or LM7806 / 7809 / 7810 / 7812 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +5V is adjustable in the range +5V to +12V by means of a potentiometer. This controller provides low ripple, low noise and fast response.
Reference : 14041
13,90 €tax incl.
11,58 € tax excl.
DISCRETE VOLTAGE REGULATOR
LM7805, Adjustable, +5V / +12V
Régulateur de Tension Discret Ajustable LM7805 +5V / +12V
This discrete voltage regulator has been designed to replace an LM7805 IC model (or LM7806 / 7809 / 7810 / 7812 with adjustment), in order to provide your audio system with a cleaner electrical signal. Its value of +5V is adjustable in the range +5V to +12V by means of a potentiometer. This controller provides low ripple, low noise and fast response. The controller only uses high-quality components such as a Toshiba low noise triode, Vishay resistors, VX Tantalum capacitors or a Bourns precision potentiometer.
The regulator is set to a basic voltage of +5V.
Product typeDiscrete voltage regulator
RegulationTransistor NPN MJE15032G
Adjustable output voltage+5V to +12V
Output current1A
Operating temperature0°C - 125°C
Max. voltage (Vin)35V DC
Dimensions13.843 x 16.383mm
Output voltage (V)
  • 10.0
  • 11.0
  • 12.0
  • 5.0
  • 6.0
  • 7.0
  • 8.0
  • 9.0
Output current (A)
  • 1.0
Input voltage (V)
  • N/A
This discrete voltage regulator has been designed to replace an LM7805 IC model (or LM7806 / 7809 / 7810 / 7812 with adjustment), in order to...
