LM7915 Discrete variable Linear Voltage Regulator -15V
This variable discrete linear LM7915 voltage regulator can replace an LM79xx regulator. It has a preset output voltage of -15V DC. Its maximum input voltage is -14 to -45 and its maximum output current is 1A.
Reference : 17601
12,90 €tax incl.
10,75 € tax excl.
LM7915
LM7915 Discrete Linear Voltage Regulator -15V
This variable discrete linear LM7915 voltage regulator can replace an LM79xx regulator. It has a preset output voltage of -15V DC. Its maximum input voltage is -14V to -45V and its maximum output current is 1A.
Make sure that you have sufficient heat dissipation, especially when the voltage difference is high.
Product typeDiscrete linear voltage regulator
Output voltage preset-15V DC
Output voltage min.-11 DC
Min input voltage-14V DC
Max input voltage-45V DC
Drop Out 3V
Max output current1A
Output voltage (V)-15.0
Output current (A)1.0
Input voltage (V)-14.0
Input voltage (V)-45.0
This variable discrete linear LM7915 voltage regulator can replace an LM79xx regulator. It has a preset output voltage of -15V DC. Its maximum...
