SIGMA79 Low Noise LDO Voltage Regulator -15V
This low noise LDO voltage regulator Sigma79 (S79) can advantageously replace a LM7915 regulator (the pinout is the same). It has an output voltage of -15V DC with a 4µV ripple.
Reference : 14975
29,90 €tax incl.
24,92 € tax excl.
Shipping date: 16-04-2025.
Sigma79
Sigma79 Régulateur de tension LDO faible bruit -15V
This low noise LDO voltage regulator Sigma79 (S79) can advantageously replace a LM7915 regulator (the pinout is the same). It has an output voltage of -15V DC with a 4µV ripple. This model is developed on the basis of the LDO TI TPS7A 3301RGW regulator. Its maximum input voltage is 35V and its maximum output current is 1A.
It is recommended that the difference between input and output voltage is not less than 0.5V and the current is not more than 0.7A. Make sure that you have sufficient heat dissipation, especially when the voltage difference is high.
Product typeLow noise LDO voltage regulator
Output voltage-15V DC
Max input voltage35V DC
Max output current1A
Ripple4µV
Output voltage (V)-15.0
Output current (A)1.0
Input voltage (V)35.0
This low noise LDO voltage regulator Sigma79 (S79) can advantageously replace a LM7915 regulator (the pinout is the same). It has an output voltage...
