JANTZEN AUDIO WAX COIL 000-8405 Waxed Taped Coil 14AWG 2mH
JANTZEN AUDIO Wax Coil 14AWG 2.00mH - Waxed tape reel
Reference : 5975
64,90 €tax incl.
54,08 € tax excl.
Jantzen Audio Wax Coil
Wax Coil Pure Copper 14AWG 2,000mH +/-2%
Wax Coil Filter Jantzen Audio
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 14AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
TypeWax Coil
MaterialsETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper
Inductance2,000mH +/-2%
RDC0,40Ω +/-5%
Coil Height37 mm
Wire AWG14AWG
Weight0,9250kg
Inductance (mh)2.0
2 reviews
géniale
celles ci sont utilisées juste avant les médiums aigus, redonne du gain et du détail à recommander
This review has been posted for JANTZEN AUDIO WAX COIL 000-8405 Waxed Taped Coil 14AWG 2mH
très bon
couplée aussi avec un condo elle alimente les deux filtres qui suivent . lLe premier pour le tweeter et le second pour les aigus. Comme les autres apporte du gain et facile à mettre en place et à souder.
