Wax Coil Pure Copper 12AWG 4,000mH +/-2%
A true vintage treasure, this coil by Jantzen is made from 99.9998% pure Copper 12AWG ribbons hardened by a polymolecular paraffin wax. The latter has been developed by Jantzen Audio so as to prevent any air pockets in-between and to allow a higher tolerance. The result is a rock-hard and vibration-free coil. Each coil is individually tested with the Clio system.
Type | Wax Coil |
Materials | ETP (Electrolytic-Tough-Pitch) C11000 / IACS certified copper |
Inductance | 4,000mH +/-2% |
RDC | 0,43Ω +/-5% |
Coil External Diameter | 118mm |
Coil Height | 55 mm |
Wire AWG | 12AWG |
Weight | 2,561kg |
