This small audio receiver will allow you to listen to your music in your living room on your Hi-Fi amplifier or in your vehicle from your Smartphone, tablet or any source compatible DLNA / Airplay / UPNP etc ...
Unlike most receivers it is not the Bluetooth technology that is used here but the Wifi allowing a signal transmission without any compression or loss as well as a much greater range.
Each device is renamed in its interface to allow you to send your music in the area of your choice (Lounge, Bedroom, Kitchen etc).
Capable of being used in direct connection with a smartphone (without being connected to an existing Wifi network) it can also be connected to your existing residential network.
Connected in Wi-Fi it allows to always have an auxiliary input in 3.5mm jack format to connect another source.
Features:/ Strong>
- Auxiliary input (3.5 mm stereo jack) Jack / jack cable supplied
- Auxiliary Output (3.5 mm stereo jack) Jack to RCA cable for simplified connection to a conventional amplifier
- Micro-USB: Charge (transformer delivered)
- Wi-Fi 802.11 g / n
- Wi-Fi / Wi-Fi client access point
- Ability to add multiple devices (renamed in their interface to be easily identified) without limit
- Audio Bypass Function
- Firmware update
- Airtry Receiver Operating Instructions in English (PDF)
Features for sharing audio content on DLNA-enabled devices:
Comparative table between Wi-Fi and bluetooth:
| WIFI connection | Bluetooth |
Network coverage | All theresidential area | Limited to 1 piece |
Hearing quality | Without loss | Loss in encoding - decoding |
User Experience | Convenient | Easy |
Limitation of compatibility | Any | limited |
Test of the Airtry by Micougnou
Possible Usage Scenarios:
Smartphone / Receiver Direct Link:
Networking on your residential home network:
Auxiliary input:
Connection delivered with the product:
Airtry DIY version also available:
