This OEM module will allow you to add DLNA / AIRPLAY connectivity to your Audio DIY.
You can now listen to your music in your living room on your hi-fi amplifier or in your vehicle from your Smartphone, tablet or any DLNA / Airplay / UPNP compatible source etc ...
Unlike most receivers it is not the Bluetooth technology that is used here but the Wifi allowing a signal transmission without any compression or loss as well as a much greater range.
Each device is renamed in its interface to allow you to send your music in the area of your choice (Lounge, Bedroom, Kitchen etc).
Capable of being used in direct connection with a smartphone (without being connected to an existing Wifi network) it can also be connected to your existing residential network.
Connected in Wi-Fi it allows to always have an auxiliary input in the 3.5 mm jack format to connect another source.
Characteristics:
Features for sharing audio content on DLNA-enabled devices:
Comparative table between Wi-Fi and bluetooth:
WIFI connection | Bluetooth | |
Network coverage | The entire residential area | Limited to 1 piece |
Hearing quality | Without loss | Loss in encoding - decoding |
User Experience | Convenient | Easy |
Limitation of compatibility | Any | limited |
Possible Usage Scenarios:
Smartphone / Receiver Direct Link:
Networking on your residential home network:
Auxiliary input:
