WIMA FKP-2 Polypropylene Capacitor 5mm 100V 150pF
Condensateur Polyester Wima FKP-2 5mm.. 150pF
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications.
Reference : 6050
0,35 €tax incl.
0,29 € tax excl.
Shipping date: 16-07-2024.
WIMA FKP-2
WIMA FKP-2 Condensateur Polyester
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low level of dielectric absorption. Their filtering capacity allows them to be used in a wide range of applications. Moreover, they have an extended service life, even at high temperatures.
Product typeCapacitor
Capacity150pF
Voltage100V
63VAC
Tolerance2.5%
DielectricPolypropylene foil (PP)
ElectrodesMetal foil
Temperature range-55°C to +100°C
Insulation resistance (@+20°C)≥ 5x105MΩ
Dielectric absorption0.05%
Operational life> 300000h
Dissipation factor (@ +20°C)≤ 3x10-4 @ 1kHz
≤ 3x10-4 @ 10kHz
≤ 4x10-4 @ 100kHz
≤ 10x10-4 @ 1MHz
RoHS
Dimensions4.5 x 6 x 7.2mm
Contacts spacing5mm
Tolerance (%)2.5
Capacitor capacitance0.00015
Rated voltage (V)100.0
Capacitor typeFilm capacitor
Capacitor formatRadial
These WIMA FKP-2 capacitors are made of a Polypropylene dielectric. They benefit from a tolerance of 2.5%, a very low dissipation factor and a low...
